Vapochill LS - couple of ques.
  • Thread starter Thread starter nick25
  • Start date Start date
N
nick25
Guest
Anyone know whether you can fit it under a PC-75 - is the 'hose' long enough to reach the cpu? Can you put it underneath at the front or would it had to go at the back - where the cpu is positioned on the mobo it would look like it would have to sit at the back of the case which i think would look a bit crappy.
Anyone know what fan(s) the vapochill LS uses? any chance you could change them for better ones i.e less dba same cfm.
Thanks.
Hi mate, you can use the Vapo with the PC75, as it has the same dimensions as the mach II AFAIK. I shouldnt see that causing you too many issues, the motherboard tray is in the correct position.
I wouldnt want to mess with the fans on the vapo for obvious reasons, for starters it will void the warranty.
well i dont think you will be able to get quieter fans and still with a higher CFM rating..
i wouldnt mess with its fans either as phil suggests...
its already a bit noisy they say with its fans...keep it as it is :)
