Rastalovich
Ya the basic theory is u`r mobo will access both memory slots at the same time, rather than just one slot.
name='raging-savage' said:matched pairs are only pairs that come off the line one after the other afaik
eg, one comes out the manuf line and then the next one get selected to go with the one before 'matching'...well thats what i thought anyway lol
if he buys another stick of exactly the same ram it should work dual channel no problem as they are both the same specs.
cheers.
name='Toxcity' said:I am running an Asus A8N SLI SE.
So your saying if I get another gig or ram I will see a huge boost?
Does it have to be the same? couldn't you get the same spec but different make?![]()
cheers.
You don't need to get matched pairs as in the sense of going on a wild goose chase to find the stick that came off the line immediately after the stick that you've already got. That would be next to impossible, unless you buy a dual channel kit.
Only dumbsh*t awkward mobo manufacturers would insist on that.
I've got 1gig (2x512) GeIL RAM in my board, they were both purchased 3 months apart and they are running in DC. All you need is each stick to be the same manufacturer, same size (obviously), same speed and everything else. Then bung 'em in slots A1 and B1 and you're away.
I was only refering to the matched for people who dont quite understand. I know that you could buy a 1gig stick or Corsair V-Select and then buy another stick later and they would work. Thats how i have 4gig, but im just trying to make it simple here.
name='PP Mguire' said:Ive tried, and it dosent.
name='PP Mguire' said:Yea, same speed and brand.
