Chris230291
Member
Hello. Can someone please brief me on these universal water blocks for GPU's?
I'm starting to think i need a custom loop, so i may as well include the GPU. My worry is that if i ever upgrade (not an avid gamer) i'll be left with an expensive paperweight, which is why the term universal sounds appealing to me.
My card is a Sapphire 6870. To be honest, i only want to watercool it for aesthetic reasons. I was adamant that a H100i was the way to go, but because i want all that custom tubing and fluid goodness, I'm starting to think custom is the way to go.
I've seen second hand parts go quite cheap on ebay etc, so I'm thinking second hand "custom" bits will fall in at around the cost of a new H100i, but look WAY better.
Also, looking at the res's, is there any reason why i can't make my own? The seem ridiculously expensive for what they are. Any "special" glues etc required so it doesn't react with the fluid? Got some really cool ideas knocking about for what i want.
Can anyone give any advice on the subject please?
Cheers,
Chris.
Cheers,
Chris.
