biscuitboy
Hi guys.
Right, I am currently running 4 250gb Drives in 2 Raid 0 arrays..
I want to buy 2 1tb spinny Drives and replace both the sata arrays with these drives.
My question is, I can transfer the array with my files on np and it will work fine, however if I transfer the volume with my OS on will it still run??
I was under the impression that if I copied the contents of the OS drive to the new array it would be located in another position and therfore windows wouldnt be able to find files etc...??
If so, what do I need to do?? Clone the OS array across first and then copy the remaining files after this?? Will it work cloning from one size volume to a larger volume??
What will happen with the partitions as I have a separate partition for the OS on the os Volume.
Cheers guys, hope this makes sense!
