Nice Nick it looks great! And that case size looks just about perfect for hauling to LAN parties and such, good choice bud.
The cable routing looks very well done for a case that size which has no real good place to hide cables such as a case like mine (yet mines almost so big it's hard to get cables long enough to hide!).
Keep up the awesome work man, lookin SXellent (in the words of Austin )
Yeah probably seated the CPU slightly off too mate.
Take it off, clean it, use AS5 on both the CPU heatsink and the XP-90 (spread it over the whole surface in a thin layer), then re-install it. Make sure when its clipped on you give the XP-90 a good wiggle to get full contact with the CPU. Also make sure the XP-90 retention bracket is screwed on properley
