The Rebel, my personal gaming rig
Looks good mate. About the GPU, I recently saw a gizmo thats made of plastic, works like an extension pole. you mount it in the bottom of the cause, then twist it out to the needed length to prop up the unsupported end. I just wish I could remember where I saw it :(
I straightened the GPU a little bit by changing the place where my PCI-E power cables come and tightened them to keep the GPU straight. No PC hardware was hurt during or after the operation.
Can we have some pics of process?
fantastic build mate! I would definitely tuck the cable in a little tighter and get some of the slack behind the motherboard, however with that said, really good rig you have!
I was scrolling down the images and thinking "Yeah, nice rig this guy has here...".
Then I got to the bottom image and thought...
I'll be adding some more pictures when I have made couple of changes, but that's going to take at least one week because I'm suuuuuper busy currently :(
Thanks everyone for your opinions, I really do appreciate them:)
I'll replace some of the fans and lights this month and see what happens. I noticed that you guys have an eye for aesthetics so what do you think, should I change all the fans into white ones and get those white BitFenix Alchemy strips + replace UV Red cathode lights with white ones to make this rig super white :D
Now that's the best idea you got, now make it happen & remember pics :crazy:
Thats a sick looking setup! How did u get that red lighting at the top though? i cant tell if its from a LED strip or some sort of fan light?
