Dicehunter
Resident Newb
So I'm quite happy with my rig so far, Love the Sabertooth X99 as I'm not a fan of mobos with lights so it's perfect for my tastes, But the colour of the armor needs to change as currently it's a beige'ish gray, It needs to go.
I'll be starting the mod once the materials arrive i.e sand paper, Paint, Thick plastic card etc.... which will be used to replace any logos that I cut out or sand over.
Current look of the mobo 14/02/2017
I'll update when the process starts within the next week or so
UPDATE 27/02/2016
Ok modding all done
All the stuff.
Fans before the corner swap.
Naked mobo NSFW !
Mobo armor cleaned, Washed, Sanded lightly, Washed again and then painted.
Fan corners replaced and I removed the Corsair stickers from the center of the fan to allow a bit more light to shine out.
Mobo armor re-installed.
Cable combs installed on the CPU 8 pin, 24 pin and GPU 6+8 pin, Fans installed with new corners and mobo put back in.
Glamour shot.
Uncompressed album
Full specs of entire setup
Intel Core i7 5930K @ 4.50GHz @1.30v
Asus TUF Sabertooth X99 - Modded
Asus ROG Strix GTX 1080 8GB G5X @ 2100/5500
Corsair Force MP500 Series NVME PCI-E M.2 SSD - 480GB
Corsair Force GT - 120GB
Corsair Neutron Series XTi - 960GB
Corsair Vengeance LPX - 32GB @ 3000MHz
Corsair H110i GT+ 2 x Corsair ML 140mm Pro White LED + Black Corners
Corsair Carbide Air 540 - Black + 3 x Corsair ML 140mm Pro White LED + Black Corners
Corsair RMi 650w 80+ Gold + Black Cablemod Kit
Corsair Scimitar RGB - Black
Corsair MM800 RGB
Corsair K65 RGB LUX Cherry MX Red
Corsair Void 7.1 RGB Wireless - Black
Custom Headset Stand
Blue Yeti Blackout Edition + Desk Mounted Mic Arm
OCUK Mega Mat 3XL Elite Tactical Gaming Surface
Western Digital Caviar Black - 4TB + 2TB - Documents, Music, Movies, Series, Mods etc.....
Asus ROG PG348Q Ultrawide 3440x1440 G-Sync IPS 100Hz
Windows 10 Professional 64 Bit Edition
UPDATE 27/02/2016
Ok modding all done
All the stuff.
Naked mobo NSFW !
Glamour shot.
Uncompressed album
Corsair MM800 RGB
