mayhem
Now if you like tech this is a interesting project due for imminent release.
Its a Small Arm CPU (ARM1176JZF-S) running at 700mhz which is the same as most low / medium end mobile phones
The primary OS will be all manner of Linux based OS's
It uses as SD card or SDHC card for storage (supect to be upwards of 128GB)
Comes with or with out Ethernet
Comes with USB, serial ports and all so a on board GPU (Broadcom BCM2835)
The following display outputs are supported on the board:
Composite video (NTSC and PAL) via an RCA plug.
HDMI 1.3a standard output.
Display Serial Interface (DSI) - via unpopulated 15-way flat flex connector.
These interfaces allow the use of a broad range of displays, including:
Televisions (HDMI or composite).
Computer monitors (HDMI/DVI-D cable) (VGA monitors would require either a composite or HDMI to VGA scan converter box).
DLP/Laser Pico Projectors (HDMI/DVI-D cable).
RAW LCD panels (DSI + interfacing hardware)
The price is between £15.00 to £25.00 depending on what version you opt for.
This could possibly make one hell of a cheap fan controller or PC monitoring PCB and will be interesting to see what comes of it. The programming is Linux based how ever given time i can see some other OS's being made for it.
Its all ready known that you can add a touch screen mobile phone screen from certain nokia's and various other branded LCDs.
Now its been developed to help kids get into this side of technology how ever its price and what it can do certainly will open up the market more for other things.
If you after more info go to http://www.raspberrypi.org/ they have forums and a wiki.
this video shows it processing HI DEF Vid at 1080p and all so doing 3d work. Impressive.
http://www.youtube.com/watch?v=te8jt-jUkm8
there is a real good peace on http://www.theregister.co.uk/2011/11/28/raspberry_pi/ and is a must read.
