TPC
I present you my new project: The Quiet Viking, another project wich is based on a rather unusual case choice but more on that later.
I already had a similar project with such a strange case some of you know it, it was called "PC-Chair" now some bells should ring about what 'case' I will choose.
First up the components wich will probably be used:
I7 4770K
Asus Sabertooth Z87
GTX 980 (770)
Corsair RM 650
8GB Crucial Ram
1TB Seagate HDD
240Gb Samsung 850 SSD
Later a custom loop with these components will be added:
Either a MO-RA3 on the side or two 240mm Rads inside the case. My Cpu block will be from EKWB and on the Gpu probably too.
Now onto the case.
I had to choose between Silverstone, Cooler Master, Bitfenix, Corsair etc. and that was not easy, so my choice fell onto...
IKEA!
Its the IKEA Oltedal if anyone is interested. And that name is the reason why my project is called "The Quiet Viking". Oltedal is a small town in Norway and when I think about Norway I think about vikings.
It is indeed rather huge, you can see that my dummy board (Full size ATX) has more than enough space in there. But that will help making my look perfect, and watercooling later will be a breeze.
My PSU will take place in the upper section aswell as my HDD and the cables will all come down from the top. I'm still not sure if I should turn the MB 90 degrees so the I/O is at the top, but I dont need to hurry to decide I just started to work and as everything comes together I will have a decision.
Feel free to ask me anything about my rather stupid idea :lol:
See you in the next Update or around the forums
