The F@H stats signature guide..
Status
Not open for further replies.
OK. In that case it's slightly different and not called -advmethods. but its the same thing.
Are you interested in how to do it? and if so you you want me to go through it now? Then it's upto you when to actually make the change.
yea . plz . if you have the time . however if you say its best to wait till after 10 WU then i'll do that
On the top left of the windows the is a drop down. Change that to expert.
Now click on the configure button to open the configure window/menu.
Click on the slots tab , in the slots box click on SMP then on the Edit button in the bottom right
Scroll the window down to the Extra slot options and click the Add button.
A small window will appear.
In Name type client-type
In value tyoe advanced
Then click the OK button on that window, OK on the Slots Window and Save on the configure Window.
Once this has been done it will finish the current work unit and the next one it downloads will be an advenced work unit. These can be bigger or smaller than the 'normal' work units. But in general their PPD is higher.
I hope that's clear enough
I am afraid i need to take out all the external links !
so this guide will be lost as well....
I will make my own site with these guides , always wanted to make that anyways
I am going to make that site today after some running............
Ray....
EDIT i will remove the links or just the whole post,
there on my own site now..........
Status
