Systin temp
Yeren
Hey all, just wondering if anyone knew what the SYSTIN temp is on HWmonitor
Mine is reading 121 degrees CELCIUS but started at 25 degress, i have done a google for this and came up with some very inconclusive results.
anyone able to help and reassure me that this is right
Personally, if the computer is running fine I'd say it's just an erroroneus reading. I have one on my system regardless of what software I use or the amibient temp is, my mainboard sensor claims it's 22°C at all time.
I assume Aida64 states the same temp for you ?
PS. nice background, any chance of a link:D
It isnt misreading them...there just isnt a probe there to even sense the temps.
It then tries to calculate the temps based on resistance, and temps of surrounding parts, and clock speeds of surrounding parts I believe - so it's always way off for temps like that.
Just ignore it, it isnt a problem - if it was true, you'd know about it
