CalVic
Member
Heya all,
I'm currently in the process of tweaking my 8350. Currently stable at 4.8Ghz at around 1.488v. Running Prime95 @ Small FFTs my temp rises to about 56ish to around 57 depending on ambient, I suspect I will never run an application that would stress the CPU to that temperature.
But I want to overclock more (Gotta get the best Price to Performance ratio eh?), and I'm already nearly at the limit due to the Max recommended core temp of 61c
So, I've been running OCCT using the Large Instruction Set, It say's that this is the best mode for error checking. But the temps are around 51 to 53 as it doesn't generate the extra heat Small instructions do.
Would it be fair to say that this is probably the realistic full load temp would be? and should I base my overclock temp limitations on this test rather than Small FFTs in Prime95 and Small Instruction Set in OCCT
Just curious as to what other folk are doing. I've seen some people reach 4.8 to 5Ghz on the 8350 using more vCore than I but saying their temp is around 51c and below using an H100 Cooler.
