Spectre vs Spectre Pro
njallday
So I'm planning on getting a few Bitfenix fans for when I order my new case (650d or Switch 810), and I was just wondering, what's do the Spectre Pros do that the normal Spectres don't (other than ever cooler looks)?
Spectres are quiet, cheap, and great looking. Just wondering if the extra $6 is worth it performance-wise
on the spectre pro's ts the blades ( their profiled ) and the guide fans on the front to make for more focused airflow (
also think it has higher static pressure
and a new type of bearing i think but not sure if the other normal spectre has that to
