Some dust in water loop
no im not hunting you pics down lol. you need to show me a pic of you rig. Loads of people forget they need empty there rig now and then and do there tubing so tight with no way of getting it back out..
And another way by the way is to syphon though you fill hole.
I will get a pick up later, it's to late now. And I can't siphon either because my res is above all my parts
. It really sounds like im F***** lol
But will see what will happen.
of course you can still syphon. Suck out some liquid, tip the pc forward and take some more out, take enough out so you can then disconnect the tubing and then empty the rest of the system.
If you have to blow to push water out ... just think about it. its not hard getting water out your system.
Yea that's what i have been considering. i need something to siphon with other than a turkey baster
