ruthless_villain
Hi, am interested in buying one of these two cases and well cant decide £10 difference between the two so i am letting you guys choose, thanks for voting
I think the RV02 is better looking case but as KaraMurat said it depends on your personal preference.
I'm not to keen on the orientation of the RV02 plus there isn't water cooling options. You could put a 360 rad in the bottom but the heat from the rad would be blowing onto the GPU and motherboard and with only the 120mm fan in the top it wouldn't have enough air flow to keep it cool.
My two cents.
Is this to replace your phantom?
I like the 650D out of the 2. For me the RV02 is too deep and has the window on the "wrong" side.
[badjoke]
That depends on how you look at it![]()
[/badjoke]
ah well went for neither in the end, went for the 700d in the end
Must be something seriously wrong with my 800D then because I have all fan slots full and the airflow is terrible. Also the sidepanels dont fit properly so they vibrate with the HDD's and the HDD noise is beyond irritating.airflow isnt as bad as some people make out either
I am contemplating the 650D myself because I might be changing my H50 for a H100 and the cases that were suggested to me wouldnt accomodate the H100 , but this 800D left me with bad feelings towards corsair cases.The 800D is a hotbox, Tom did a review (way back) and pointed out all the flaws with the case which Corsair said it took note and would ensure the newer cases it made performed much better with airflow.
