T Talonaer New member Aug 31, 2008 #1 i have an asus 8800 gts 512,,,could i SLI this with any 8800 gts 512 or only asus made ones....i thought had to be identical incl manufacture but read a few things which are making me think differently....advice me
SuB The Webmaster Aug 31, 2008 #2 to my knowledge any will work, they removed the branding limitation a bit back as far as i know?
L Luigi New member Aug 31, 2008 #3 Its more the bios than the branding, but yes that will work fine AFAIK, its only tri-sli you have to have matching bios's
G gotmaxpower New member Sep 1, 2008 #5 Back around the ~6800GT's, cards in SLi had to be almost identical or they wouldnt work together.
N Nick259 New member Sep 7, 2008 #6 they should work fine together, however if one of them is a pre overclocked version it will run at the same speed as the slower one, as far as i know.
