Show your F@H Room/Rig !!
My folding computers
Since I now have 3 computers running daily in my computer room, I decided to take some pictures for you to see. ;)
Here's the i5 rig.
It has a
i5 2400
8GB's of RAM
120GB SSD + 150GB Raptor
GTX 560Ti
Here's the i3 and C2D rig's, the C2D to the left and the i3 to the right.
Specs for the i3 is
i3 2120
4GB's of RAM
1TB WD Green
GTX280 with Accelero Pro GTX :rolleyes:
Specs for the C2D
Core 2 Duo E7500
4GB's of RAM
250GB HDD
HD5750
Pulling 750'ish watts from the wall, not too bad, considering the amount of computers in there :lol:
Room turns hot after a while, left the door closed one night, and the temperatures went up to 28 degrees celsius! :o
Screenshot from the Core 2 Duo rig ;)
From the i3 rig :)
And last, for the i5 rig :)
They all work very well, and has been stable since I turned them on (and installed the updates, updated AVG and so on)
K
They are both dual hex core xeons HT'd.
The R710 (bottom one) has a pair of X5670's
The T610 has a pair of X5650's
They are good for about 100k PPD each, although the 710's probably pushing closer to 120K due to the higher clock speed. I just stuck Ubuntu Server on them both kicked them off and left them.
Wow, 100k each? That's nuts! I bet those were very expensive as well :P I believed F@H was mostly about using the GPU? Maybe I'll set up my not so GPU computers as well?
My F@H room kinda build up again,
as i thought i was going to move a week back (reason i stopped the F@H for that time being),
just need to build my little P20 rig,
might as well do it these days.....:whipping:
SnW. You're going to trip the breakers again at this rate! lol
