OK, after 5 mountings, double checking the proper contact of the evap against the CPU, starting the PC from the GT without the evap mounted, starting the GT with a screw driver, nothing works. Same old message: Bad BIOS checksum.
Impossible to boot. Reflashed a dozen times, nothing.
But as soon as I go back to air cooling, no problems at all...
Should I consider changing my mobo? The GT seems to work fine, cooling down to -62 (as displayed), starting the PC at -50.
I noticed that very often, when I removing the evap head, the CPU is not anymore in its socket, bu I guess this is coming when I remove the head.
Is there any known incompatibility with the P4C800 Dlxe mobo? (not the E one)
Help please
Help please
