Mr. Smith
NickS said:Depending on how much you want to spend, your case, etc.. this would be a great setup.
CPU Block: AquaXtreme MP-05 Pro LE
GPU Blocks: 2x AquaXtreme MP-1
Radiator: Swiftech MCR-220
Fans: 2x Yate Loon D12SL-12 47CFM
Pump: 2x Alphacool DDC Ultrahttp://www.petrastechshop.com/aq50in12pu.html
Tubing: 10 Feet - 1/2" ID 3/4" OD Masterkleer
Fillport: Petra's Delrin Fillport/Cap
T-Line: 1/2" OD T-Fitting
Radbox: Swiftech MCB-120
Coolant/Additive: Pentosin G11 Blue Additive (4 oz)
You don't necesarrily need that additive, you can choose any color/type. You don't need a Delrin fillport either, there are metal ones too.
Anyway, thats what I think is suitable. Two pumps will give you the pressure you need along with solid flow to cool your components down. The Alphacool DDC is UN BEATABLE, and two will give you oodles of head. The MP-1 GPU block is the best GPU block out there, no doubt. The Yate Loon fans are quiet, the MP-05 Pro LE is within 2-3*C of the Swiftech Storm, and is cheaper. The radiator outperforms the Black Ice Pro II, and is great for silent watercooling.
That is pretty much the ultimate setup, but is pricey. Hope you enjoy, and good luck.
Looks good, little pricey...
If i ditch the t-line and opt for a res, is that the only alteration to the above setup i'd need to make.
Also, with the 7/16" tubing, would i need different blocks. For each diameter, 3/8", 7/16" and 1/2" do you need specific compatible blocks, or can you mix?
Thanks
