Screwing up your system (Water cooling)
r8msify
So i just watched this video
And i found it quite amusing how he's really thinking his system is setup correctly and the fact that he even powered up the whole system without running any leaktests at all.
noooooooooooooooooooo!!
argh!!
that was painful to watch/listen to (felt sorry for the pump)
also did he have the whole system powered while failing to bleed it?!!
argh!!
Yes, that is exactly what he did. and he failed badly!
But i haven't done a custom loop water cooling system before and this guy made me more afraid of trying it seeing as how he failed..
TTL did a vid showing how he does it, i think it was ORCA, and he did not start the pump till his system was primed. the pump sounded happy lol well compared to that guys omg thats was bad.
i seen the glowing rog logo and thought aw naw he dih'ent then i seen the 24pin and was like aw crap he did. that processor had zero cooling for a good length of time.
tard
you just unplug the motherboard then connect the green cable (in 24 pin) to any black (ground) with a piece of wire, that will start the PSU and the pump/fans without any power going to the motherboard. If it leaks nothing is damaged.
