BaxtertheFly
Some closeups on the welds, and also the frame is finished, i even figured out how to fix the bend caused by heat to aluminum, tho the bend isn't big, 2-3 degrees it is still annoying and it bends entire body, all that caused because i dont have horisontal cubetube above the components (i left it open so i can tinker with it with ease... i figured few ways to fix that, and i hope you guys will like it...
The 2-3 degrees influence in overall look of the case...
it is causing the difference of about 1-2mm from one side to the other and it pisses me off.
FIX! The simple solution.. threaded stick, with it i could adjust it all
the pictures are low quality because of the lighting and my primary camera died... using camcorder to take photos
loosening of the screw acts like a car lift, stretches the frame, and i got exactly what i needed
Hope you guys like this
p.s. the entire case is sanded now, it has been Gited and is ready for its first paintjob... also, going to get stuff from CoolerMaster HQ here in Serbia tomorrow morning
