Sapphire X1950 Pro refuses to start
jdowny
I recently got a Sapphire X1950 Pro graphics card and I thought that I installed it fine - The old card was removed, the new one was put in with the PCI Express connector attatched. Everything was put back in place, but it doesn't work properly - When the computer is started, only the monitor's logo comes up and nothing else.
Specs -
Intel Pentium D 805 Dual Core Processor
1024MB Dual channel memory
250GB Serial ATA Hard Drive
Things that were included with the package:
- The graphics card
- 3 TV output/input cables
- 2 DVI to VGA Adapters
- A Crossfire card
- An installation CD
- A VGA cable
As far as I know the card installed fine. I've checked all the monitor ports, checked that the card is in properly, and checked that the correct wires are all plugged in. But any suggestions would be really appreciated! I 'm starting to think that I've been royally swindled.
The PSU manufacturer seems to be Dell, that's the only name I could find, although I didn't know they did PSUs. The model is L305P - 00, if it helps.
I uninstalled the old driver okay I think. I went to the My Computer icon, right clicked it, went to the driver tab and clicked uninstall. I'm not sure if I was meant to do anything else.
EDIT - I think that the PSU is the problem. At 300W it's probably not enough power. Would anyone recommend another PSU? I've seen a 500W PSU for about £15 which looks good.
If u`r 300w was a reaaally good quality manuf, I`d be semi happy with it.
I`d be more happy if it were a solid 350w.
Completely sound of mind if it were a really good quality 400w.
If the psus are from generic stock, some no-name brand that not many people tend to sell, I`d trust them somewhere around 75% of what they claim to be. In some cases even that is generous. But hey, some people get lucky.
name='ionicle' said:
U can`t argue with that tbh, and the QoS alongside OC3D, ST and them quite honestly u don`t see too often.
Question I`d be asking myself tho, is am I looking to `invest` in a psu (meaning I`d hope to use it in my next build too) - or am I looking for a bargain price vS quality to tide me over for the current system I have. In which case ST have this on offer atm: which of course comes with all the ST support and offers as an OC3D member - and Scan have one of my favorite makes atm , but of course that will require postage and etc.
Be sure u have the correct connections for u`r mobo and drives etc whilst u`r looking tho.
Thanks for your help. I've gone with the Scan 'Silverpower' PSU. I'll let you know if it helps or not.
I'm having troubles connecting the PCI-Express power connector to the hard drive. I've got a 250GB Serial ATA Hard Drive, but the problem is that it's encased in two metal pieces - the standard thick aluminium layer on top which has the label on, and another thick case that surrounds the outside.
Does anyone whether I need to take this off to reach the socket? In which case I think I need to get a special screwdriver.
i found going to amd site to download up-dated driver best plan because if you load cd driver you still have to un-install before you get updated driver
Thanks for your help but I managed to fix the problem. I should have posted on here when I fixed it, but the PSU that I was using didn't have the right connections and so all I needed was an extension cable of sorts and it now works beautifully.
But thanks for the help nonetheless
