I have a bit of a dilemma i want to use the 240mm rad but it will have to be mounted externally on my enforcer on the top which it can and i dont mind but i dunno how to get the tubes from inside the case to the rad as the water cooling holes are too close to the top and i would kink the hose trying to get it in there.
Other option is to get the 120mm kit and mount the 120mm rad internally in push/pull config which one shall i get as i had a antec 620 i would get 59C on my 4Ghz OC i dont want huge OC so if the 120 kit will be enough ill get that as it cheaper and easier. but if the 240mm kit is going to be better how will i hook it up on my case?
