AlienALX
Well-known member
Sun decided to grace me with its presence so I responded in kind and took some photos. Firstly my nice tidy desk.
Some one has some tidying to do... Note : PC is very messy inside having been built and rebuilt about ten times last night.
Roof back on.
In this pic you can see lots of hard drives. However, look around them. There is a black/transparent piece that covers the entire side. It clips in, has lots of wires hidden under it (including the front panel ones I was trying to get to !) and is a complete sod to get off and back on again.
The pump, finally behaving itself ( I had to literally fill the res up to the limit to stop it spitting and bubbling, though that's the res's fault really)
The front. You will notice the chrome res bolts are gone and I replaced with black button hex bolts instead.
And a quick side profile shot, though again everything is about as messy as it can be right now. I got a refund on an Ebay con so when it hits the account I think I am going to order some 16 hole combs and fit them. IIRC the pins come out of the Bitfenix Alchemy quite well?
Roof back on.
