RedStorm Update: GPU
I'd like to present my rig:
The PC is about one year old, but recently I added a custom water loop (my first). Luckily I din't flood anything :lol: At the moment it only cools the CPU however I plan to buy a new GPU next year which will be than added to my loop. I also plan to add 2 120 Fans on the bottom of the 240 Rad and maybe add a fan controller.
Here are the specs:
i5 3570k @4.2 Ghz
ASRock z77 Pro 4
8 GB Corsair Vengeance lp 1600 9-9-9-24 RAM
Sapphire 7870 @ 1200/1400
Samsung 830 128GB SSD
Samsung HD103SJ 1TB HDD
be quiet! e9 480W
CM Storm Enforcer
And here the water cooling:
XSPC Raystorm
Aquacomputer aqualis ECO 100 ml Res
Phobya Xtreme 200 Radiator
Black Ice Stealth 240 Radiator
16/10mm tubing
Aquacomputer Aquastream XT
Here is how the system looked on air:
And here the current state:
I hope you like it
Here are the specs:
i5 3570k @4.2 Ghz
ASRock z77 Pro 4
be quiet! e9 480W
CM Storm Enforcer
XSPC Raystorm
16/10mm tubing
I hope you like it
