Recommend me 140mm fans..
SuB
The Webmaster
Looking to replace Betfenix Spectre Pro's because they're rubbish.
high pressure, low noise for water cooling please... I keep looking but just can't find anything i recognise or like the look of.
Colour scheme is black/white/grey... I'm open to ideas though because tbh I want the performance.
Nothing "flashy" please. Must be quiet as well, i'm happy to low-volt to do this if they still perform...
Ta lads.
Sub
How about Akasa Apaches ?
They push a good amount of air and have a decent static pressure.
And theyare all black if you dont mind that.
the swiftech helix 140 look like the AP-15 radiator fans.. decent static and
noise is tolerable. they do undervolt well from a molex (i do not use fan controllers)
with no clicks or groans. the bestest 140 fan i like is the BGears B-Blaster 140.
monster stats, can be a loud monkey on 12v, but awesome 7v performance.
i painted my blade assemblies white for the effect..
could also look for the corsair SP's
looking for 140mm fans.. corsair doesnt have a SP140, yet..
Thanks for the suggestions, I'll have a neb around n see what there is.
I was looking at Noctua, simply because of performance :) but their 140mm range confuses me and don't look to be at the same level of performance as their popular 120mm ones. I should also point out, 3 pin none pwm fans please :)
Thanks for the help so far lads.
Don't Silverstone make penetrators in that size?
I heard they were excellent for creating a lot of pressure without making loads of noise.
I have just bought a 140mm Akasa Viper S-Flow . From a quick test and play around , so far it is very good . 600-1600 RPM , 12.5 - 26.01 dBa , pretty load on full whack but on a reducer fine ,max air flow is 110.61 cfm and the static pressure is 3.12 mm - H20 . I also have 2 120mm on my rad and my god they shift somw air . The only problem is they are black / yellow .
Akasa Viper 140 or Apache 140 or Swiftech Helix 140.
Akasa's specifications looking like a wishlist.
I don't believe in this data anymore.
Got the 120mm PWM version of Apache and Helix and at the same RPM the Helix is moving a lot more Air on the same Noiselevel and the airflow is a lot more directive.
