TPC
Hi there!
I'm usually not a fan of threads like this but I just found myself without a clue what to do.
I'm searching for a new set of 120mm fans to replace my Noctua Redux S12 700rpm as they just simply don't cut it with their 0.5 H20 at full speed.
What they're used for is my GPU cooler, the Rajintek Morpheus so static pressure is needed.
When you recommend me a fan please try and say why it's good and not just be like "dat is da gr8est". Same goes stuff you know about fans recommended by others. The thing I'd most likely to hear would be a recommendation based on experience, long term if that's not asking too much for.
It's your turn now
thanks in advance!
It's your turn now
thanks in advance!
