My simple build(s). 4770k + Ryzen R7 1700
So, new here. Thought I'd post my current rig, and let slip some plans for the "near" future.
First off, a picture...
So, my current build is coming up for a couple years old. Very little has changed.
Pioneer 16x BDRW Multilayer 128GB
NZXT Phantom 530 Black Full Tower Case
Intel Core i7 4770K 3.50GHz Socket 1150 8MB Cache Retail Boxed Processor
Kingston 8GB 2400MHz DDR3 Non-ECC CL11 DIMM (Kit of 2) XMP Predator Series
Corsair AF120 LED White Quiet Edition High Airflow 120mm Fan Twin Pack
Gigabyte GA-H87-HD3 Socket 1150 VGA DVI HDMI ATX Motherboard
Samsung 120GB SSD 840 EVO - SSD Only
Corsair Hydro Series H60 2013 model High Performance Liquid CPU Cooler
Corsair RM 650W Fully Modular 80+ Gold Power Supply
A couple things have changed though. I know run 16GB of Crucial RAM (just 1600MHz, basic stuff).
Also, the SDD quickly ran out of space, so was replaced with a 500 GB unit.
Added some fans:
Corsair AF120 LED Blue Quiet Edition High Airflow 120mm Fan Twin Pack
Corsair AF140 LED Blue Quiet Edition High Airflow 140mm Fan
Corsair SP120 120mm Low Noise High Pressure Fan for Radiators Heatsinks Dual Pack.
So, as I'm sure you will have noticed, no GPU, or sound card. Soundcard is on its way, as I decided I would like to upgrade my sounds. But I don't game on this system, preferring my xbox for that.
The rig was built for encoding video. And serving media out to my renderers throughout my property. So running Serviio and Plex. Obviously I have added some HDD's. Currently have 2 6TB WD's and a 2TB for local docs and stuff. I have just lost a 3TB drive though, so will be adding another 6TB shortly.
So, future plans?
Well, I wanted to move to a more NAS-like solution. So I bought a QNAP TS453A. I hated it. I am NOT a fan of Linux, not at all. So returned it. And I planned on building a dedicated NAS, running an OS I could get along with. So I'll be throwing Windows on it. Probably not the best for some of the things I want to do, but the stuff I find most important to me, i.e. proper automation, I can already achieve with my current windows machine.
So, I dug out an old Dell OptiPlex I had sitting around, installed Windows 10, and set it up as a headless system to test. Confirmed I could do what I wanted with it, so then built a "basket" to see what I needed. And started researching components.
During my research, I clocked a video of a guy who has his NAS doing his video transcoding. Excellent idea. Means I'll need a bigger CPU though on the NAS than originally planned. So decided I will re-house my current build into a smaller case, and set that up as the NAS. And build myself a new daily driver. So started looking at i5's for the daily machine.
Then clocked all the hype about the new AMD Zen chips. So that put the build on hold while I await pricing and some benchmarks on the new AMD and intel chips, to see where the market lies. Hopefully I can get something decent quick for around £200 (for the CPU).
In the meantime, there is some gear I am ready to buy. I haven't been able to OC my CPU, as the cooler is absolutely rubbish. It looks nice and all, but the H60 simply isn't man enough for a 4770k. Even on a normal clock, the temp can easily hit the 90's on full load, and low 40's on idle. I never though to under-volt it until a recent video on here comparing 30 coolers or something. So will try that. But, as this CPU will be going in a headless rig, I want to make absolutely sure that it remains cool enough. So a new cooler will be required. Love my AIO's look, but I'm thinking of going back to air to keep costs down a bit.
Added some fans:
So, future plans?
