maverik-sg1
Just a quick one on re-gassing:
I am tempted by the lure of super phase change cooling, either re-gassing, or upgrade to chilly/Baker but am I right in assuming:
The fans have to be set on turbo.
The unit (Chilly, Baker or Re-Gas) is considerably more noisey than a standard machII
CPU must be kept under load to prevent freezing.
Plenty of exotic material should be used on surrounding components to prevent condensation.
That fitting and removing this exotic material is at best time consuming, at worst is incredibly difficult to cut to size and fit and even worse to remove?
Would a re-gas take for ages (six weeks)? I can't be without my beloved unit for more than a week.
Also, has anyone considered using larger than 120mm fans on a cooler to improve air flow at a reduced noise level?
If noise levels was one of the higher priorities when considering which unit to buy would you:
A) Buy a Chilly One
B) Buy a Baker Extreme
c) Re-Gas to R507 (although someone in Japan uses R1152)
d) Stick with what you've got because your expectations are too high and you are too impatient to spend the time installing all of the ancillaries correctly
A) Buy a Chilly One
