RamDisk?
circit
Can somebody explain a bit to me about what ramdisk. When he showed the speed of it, i was amazed.
http://www.youtube.com/watch?v=nP8Q-7Mdztg
At around 15:30
In simple terms, I believe it is a super SSD, allowing you to use some of your RAM as an SSD.
I think you used to be able to buy PCI cards (RAWZ was selling some) that allow you to install extra RAM in your system for this specific purpose.
as far as i know you cant store data on them though. which means that if you turn your rig off the data will be gone. they can be useful to test a very high bandwidth connection, like a 10 gb up down, because the drives you use for the file transfer need to be fast enough not to bottleneck the network
I thought you could download entirely software based ramdisk programmes - not sure how that'd work though.
Yeah it's like how with APUs you set aside some ram for the Vram, with ramdisks, you just set aside ram for mass storage instead.
10x faster than SSD I believe
correct its gone when pc is powered off or rebooted. It also has the tendency to slow down the shut down and boot up of your rig. but while running it can have good speeds. my best analogy for its use is as a caching tool.
Not much point loading a game on to it and using sleep mode instead of shut down though, because you'd only end up waiting on everyone else's game to load anyway while your's has already loaded but you can't start till they do. Good for caching design suites like Adobe's and 3D engines though, or hundreds of tabs in your browser, should you have that many.
RAM Drives in the ol days of DOS were created to
access files and programs faster than the HDD could
or that the data bus could deliver.
now cache programs and files need access and on SSD
the write function is slower. hence using allocated
memory instead of SSD is where the speed comes from.
RAM drives where non-exsistant after shutdown. so
anything in the RAM drive is gone, but the drive is
recreated upon boot up via autoexec.bat commands.
airdeano
i remember TTL mentioning this technology on his youtube chanel , does anyone know what video it was in ????
and does ayone know if this would work on a RAID config??? (using it as ram cache)
TTL mentioned it in his subscriber #15 video, as for your second Q iwould ask TTL himself for that one!
