All -
Background - I had a catastrophic loss of data once and it sucked. I began using Carbonite to backup my system, but it runs very slow when updating. Considering I have about 1.5 TB of critical data, I am getting impatient.
I am currently thinking of a new build that will include a RAID 10 setup but have some questions.
1. I was told having a RAID 10 configured through a motherboard does NOTHING to protect your data if the motherboard fails or if you upgrade later to another motherboard since the RAID configuration data is tied to the specific motherboard. I was told I would be better off buying a true hardware RAID controller card opposed to using the motherboard as this would allow me to move the configuration should I ever upgrade. Thoughts on this?
2. I was also told that setting up a 4x disk RAID 10 would eventually fail since all the drives would be the same age, running the same amount of time (24/7), and likely begin to fail at the same time? Any mathmeticians have statistical odds on this?? Joking on that last part.
3. Is there another viable backup option other than the obvious buy external hard drives? I understand that option, but what software is out there that can run in the background and write/update the external drives as my main system is updated with data?
4. Any other ideas???
Thanks for the feedback!
