r9 390x max temp
BenjiGoneMad
The 290x had a normal operating temperature of 95C, how is the 390x compared to that, is 95C within normal range or how high can i safely push the card?
Kind Regards Benji
The 290x and 390x CAN operate at 95c safely, whether or not you would actually want it to is what matters here.
But honestly 95c is tops, anything over that is simply not necessary. Or indicates a problem with either the cooler or design.
