quietfreek
Well here we go this is my work in progress:
Wooden chassis for rads:
Pump box complete with 4.9 kg of lead soundproofing - should stop the thing resonating
Rads in place and 25mm sound deadening foam for the high frequencies
the view from the top now ive got it primed
work to do:
comments / sugestions all welcome (if your not mean
work to do:
- origanally designed to use a hydor l20 - ive now realised that its a
pump and needs to die so ive got to re work the case for 12v from 240 to take a ddc pro
- create loop for GFX card (probs mounted on case)
