SuB
The Webmaster
So I've seen that primochill stuff, looks really nice. I do not however, like the fittings they look waaay too chunky for my liking.
The look I want to go for basically, is metallic fittings/elbows etc, but with straight tubing, I don't want the fittings for the tube to be wider in diameter than the fittings themselves (if possible, or at the very least, only slightly wider)
I think i've seen someone do this using the Sli tube fittings from bitspower, are these the ones to use?
Also which tubing?
Secondly, I notice on the primochill listings on ST that it says not to use glycol fluids, does anyone happen to know off hand if Feser One is 'compatible' with this tubing.. I know what putting alcohol on heated acrylic can do, so I really don't want it to be cracking, but this is my go-to fluid for water builds.
Edit: found it's ingredient list
So yeah, anyone had issues with acrylic tubing and stuff like this?
Cheers lads, always nice to draw on the knowledge of the experts here I know we have a couple of acrylic tube users in here, so share the love!
Also which tubing?
Ingredients:
Aqua Bidestillata
Ethylene-Glycol / Ethanediol - Feser Base T
Inhibitors
UV-color pigments
