Hi all,
Not so long ago I did my 1st watercooling with flexi tubes and thermaltake rads & fittings. That PC is now gone and I'm read to do another in a NZXT Manta white & Black.
Looking online I can see a video which was done bitwit and this is pretty much the exact setup I want to accomplish:
Im not to sure that I like his chrome fittings though and would like get white ones if they exist.
So I'm looking for recommendations for fittings for hard tubing, also as first time hard tuber what do you recommend for the type of tubing and thickness ? Looking around the web 12mm/16mm PETG seems to be a common choice.
Another thing on the video is the pump mounted to the front rad, anybody know what part this is ? Is there anything better than this on the market ?
Ultimate silence with Ultimate performance is my goal
Cheers
Cheers
