PSU for CrossFire
tiribomba
hello all,i got a 5870 and i want to add another one in my gaming rig,but im not sure if my PSU will be good enough.
my spec are these
i7 960 stock
rampage III extreme
creative xtreme gamer
6gb ram 1.5 v
5870 stock
4x 7.200HDD
6x case fans
1x ODD
and PSU is this one http://www.coolermaster.com/product.php?product_id=4202
if i will have to upgrade the PSU i will never buy another 5870,and just be happy with what i have now
well according to coolermasters own little calculator you will only need 620watt to power your current system. So I think it will work fine. but the issue is. Does you Power supply have an additional gpu power leads?
nope it has only 2 pcie 6+2,but i think it will do the trick with 2 molex to 6 pin
If you can go 750-850 if you want to add stuff later, better to have more and not need it than need it and not have it.
m8 read the post and then tell me to upgrade the PSU "if i will have to upgrade the PSU i will never buy another 5870,and just be happy with what i have now"
