PSU: CORSAIR HX520: Suitable?
name='markkleb' said:
Yep, and to be honest a single 8800 card should be more than enough for quite some time...
I will probably go for the 520 unless XMS can give more info on the silver power.
Just in case anyone is mislead, I am getting a HIS x1950 video card, the reason I asked is because I may upgrade in the future... and dont want to have to change everything..
I had a chance to read the review on the SilverPower PS and it looks VERY NICE
Great review too GUYS:worship:
I would imagine you couldnt go wrong with either choice. The main difference I saw was that the Corsair has modular cables. That would allow you to only use cables you needed making the installation cleaner.
but the SilverPower is a looker:cool:
cOULD YOU LINK ME TO THE SILVERPOWER REVIEW? xms SAID IT WAS BEST IN CLASS BUT i COULDNT FIND A SILVERPOWER REVIEW WITH THE BEST OF CLASS AWARD...
the 520 would run just about any video card. (same with the 600)
I dont think the difference between the 2 is much. I like that the Corsair has 3 12V rails (the 600 watt only has 2)
And I like the modular cables of the Corsair as well.
I dont think the Silverpower is available here in the states yet so I dont know where it is or how much.
Ok basically two contendors, the 520 and the SilverPower.
I have to wait to get my free delivery coupon off specialtech, so everyone has until then to post their opinions.
Thanks
name='tomclowes' said:
That has an editors choice award, but where is the best in class thing?
Sorry my bad - not thinking straight. Anyway, Editors Choice isn't to be sniffed at :worship:
I just had a simlar choice and I went with the SilverPower. I should get it 2day and ill post and tell u how it is. I like that it only has 1 120mm fan so it will be quieter than my old Hiper 580w. Specs in sig.
You are a bad bad person !!! :nono: :D
Sweet. Basically if specialtech get back to me with a coupon in the next 3 hours Ill get the 520. Otherwise the silver power.
Ok just poped in my SilverPower and pld css with everything oced. Its seems fine, no probs, and is very quiet :)
One thing, one of the cables wasnt long enough to put all 3 of my HD's (non SATA Powered) onto it. So I had to use an extension cable that i had. Apart from that i love it :) blue matches my other fans.
Hmm sounds sweet, shame I just ordered the 520. Should I be regretting my decision?? (the blue LED would have been cool) I probably ended up saving £10 getting the 520 over the silver power.
You should be fine with the Corsair, as long as its a good make and powerful enough them ur onto a winner.
They are usually the factors involved in choosing a PSU :D
Anyway hopefully we both have winners.
