PSP 8 Problem
fatty
Ok I have a full version of paint shop pro 8 now my problem is when I install it, windows comes up with failed to updat the registry so I go do a quick regedit reboot re install try again but no same message....has anyone else had this problem???
Oh and dont get me started on winzip
Nah use regedit and adjust the permissions all it was I have sorted it all if anyone else needs to know I will post???
I use to use PSP8 and never had any problems. :)
Corel seems to have bought it now, and the latest release is called Corel PSP X, which seems to be just about the same with a little bit of modding to the user interface.
I think it was because I installed the version that came with the cpc benchmark thingy then found my full version disk and re installed that it just screwed with the permissions
name='justin' said:
iv had the same problem with my sisters laptop, maybe a worm going around?
Ok I'm confused, how could this possibly be a worm aimed at just PSP 8? That would make no sense at all or benefit any hacker at all lol.
