Hey there,
I need to consult some peeps with some good water cooling exp.
Im happy with my rig atm, (3.2 @ 4386 1:1) but now I wanna start work on my grfx / Northbridge. (the zalman isn’t enough
)I don’t want to start putting more stuff outside the box and would prefer to house all the water cooling bits inside one unit so I was thinking about something like the cooler master aquagate
http://www.coolermaster.com.br/index.php?LT=english&Language_s=6&url_place=product&p_serial=ALC-U01&other_title=0
The specs are as follows
Dimension 220mm (L) x 148mm (W) x 88mm (H)
Case Material Aluminum
Fan Dimension 80x80x25 mm
Fan Speed 2000 / 3100 / 4600 rpm
Fan Bearing Type Rifle bearing
Fan Voltage Rating 12V
Noise Level 23 / 34 / 49 dB
Power supply AC power (indoor: 110V and 220V) and DC power (DC 12V)
Pump 110V, AC 9W
Power consumption DC 12V, 2.2 W
Water Block Material Copper and Acrylic
Weight 2kg (Main Unit) / 5Kg (Total)
Thermal Resistance Rca 0.31 / 0.25 / 0.23 C/W (tested with p4 3.06G)
Application AMD K7 (socket 462), K8 (socket 754/940) and Intel P4 (socket 478)
The best thing about this for me is that it fits inside 2 X 5 ¼ inch slots. From this picture it looks as if the cpu block could be changed,
and with some extra hose I could put the NB and grfx in the same loop. My only worry about this is as the unit is shipped with just the cpu block will the unit pump be powerful enough to cool two components. Well more like 4 components as I intend to use this ridiculous card mod from http://www.wassergekuehlt.de/ for my 9800 XT.
Pump 110V, AC 9W
