project richy's new rig
ok guys need help should i stick with noctuas 1200rpm for the rads or go with something like the silverstone fm123 or even use the noctuas in push pull config help greatly appreciated:worship:
Yeah I mentioned in a previous thread that the Noctua's don't provide enough static pressure...get yourself some Yate Loons
i really like the silverstone fm123 so much cfm plus controllable
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=615591
Manufacturer: Silverstone Tech.
Socket Compatibility:
Approx Fan Speed: 900 ~ 2600 rpm
Fan Airflow: 40.7 ~ 106.3 CFM
Sound Level: 17.5dB(A) @ 900rpm , 39.5 dB(A) @ 2600rpm dB
Base Material: Plastic
Adjustable Fan Speed Controller:
for the extra few quid its got to be worth the gain in cfm ?
anybody would you go for 5 of these or 5 yate loons ?
pics to come just waiting for new camera to arrive top pa 120.2 mounted, fan install for hard drives, pumps mounted with danger den fillports upside down ,teflon tape attatched for motherboard tray runners ,front buttons changed ,25cm fan installed on window ,pics will tell more
How can you afford all of this :O lol.. new mortgage? :P i seriously cant wait for some pics of this beasttyyy....
heres a few pics guys more work still to do :D
Wow looking really good!
That looks klike a really tight space, how did you get such a clean water loop into that small space? (Piccar 2) ;)
hope to see some OC3D stickers on ur fans when we release them :p lol
good luck with the build, looks like a nice rig bud
Thanks mostly to kempez and red.sky for their great guides measure twice cut once and take your time and lots of bits for your dremmel really helped me
thanks first go at water loops 2 laing d5's, two delrin filports and the 1200w psu take up alot but its a nice big space in the bottom of the tj07
at least it was lol still got the pa120.3 to go in there yet
and davos of course when you have them and when my silverstone fm121 110.6cfm fans get here
