Project: Nuclear Fission
Im glad u went for the 3930k. My parents are on te boat over to manchester i hope i can persuade them to all by scan for me and pick me up some dominator gt 16gb KITS. Are they just aftermarket ramsinks
DDC bay res will be the LOUDEST thing in that rig.... Very bad choice :/
Also please remove that USB 3 thing from the back, dear god that looks aweful inside.
Yeah, I didn't realize it would look that bad... I can mount it at the front but I really don't need it... So many USB posts on the motherboard anyway.
Also, y is the bay res so loud?
I think it looks brilliant mate
Haha, thanks, but I will remove the USB 3.0 bracket.
What reservoir would you guys recommend over the XSPC BayRes?
I have a 'spare' Koolance PMP 450 pump, so should I use that instead of the MCP355 and buy a new res?
I have two pumps, a Swiftech MCP 355 (Laing DDC), and a Koolance PMP450 Variable Speed (Laing D5)
I already bought the XSPC Bay-Res for the MCP 355 pump, but I can sell it to a friend.
If the PMP450 is better, I can buy a reservoir for it.
Decided to use the Laing D5 pump. If anyone thinks otherwise, please state why?
Any suggestions on a reservoir? I do prefer the dual bay resevoirs
I was looking at the Koolance RP450 or 452, but I cannot find one in Australia. Is it possible to get one of these in a single pump edition?
Well, I just bought two EVGA GTX480's and Koolance VID NX480 waterblocks;
Is there a way to change the light colour, or is that blue the coolant?
Should I run a Parallel or Serial setup with my graphics cards?
Does it make much difference?
Dont do parallel, slower flow over both = less heat being taken out of each, if its 1 loop just do cpu > gpu > gpu or gpu > gpu > cpu, makes little to no difference the order aslong as its 1 run.
The waterblocks use LED's to light them up, but they have a strange 4 pin, not the usual 4 pin fan connector though
