ok my understanding is that ATACS is the print not the material. I guess what I'm asking is for a name for the product you used. And if ya have time you should do us up a guide for it, cause from what I see you have it down pretty good. I might just have to get back into some serious projects after my move.
Yes, ATACS is just the patern.. It's called "Hydrodipping" and all you need is the film (of your choice) tap water, masking tape, a large container and a can of aerosol activator..
I learned this, same as cable sleeving... from youtube
