Project: Give my ears peace
Can I just add that u take some excellent photos m8y. U`r stuff really gets promoted well by the pictures u`r taking.
Case looks tremendous, love the 1st shot that also appears bullet-ridden lol
Great job.
Thanks guys :). I really appreciate the comments about the pictures Rastalovich, my digital camera is pretty old (it doesn't even have macro) so it takes a bit of effort to get the pictures right.
The loop does get a bit complicated at the T-line. I would have preferred to route the tubing straight down into the pump but this put a lot of torque on the tubing and it was difficult to keep the T-line vertical. In the end I had to use a longer tubing run.
I know noise is subjective but I would say the noise level is quiet but certainly not silent (it's slightly louder than the hum from my speakers' transformer :D). However, the quality of the noise is a low-ish pitched hum, the majority of which I'm sure comes from the pump so I might buy some of the gel material I see some people put under their pumps to reduce vibrations.
I'll measure the idle/load temps now. I wasn't sure whether to give the AS5 time to cure but with the lower temps now it'll probably take ages :D.
OK, for those of you who are interested I measured the CPU, chipset and GPU temps for Prime95 on both cores, 3DMark06 and RTHDRIBL 1.2 (Real-Time High Dynamic Range Image-Based Lighting). MBM5 was used to log the temps and calculate the averages (I did exactly the same beforehand when I was on air).
I hope this table looks OK for everyone because I had to bodge some HTML to get everything lined up. I've shown the peak temps for 3DMark06 since the 'idle' periods inbetween loading 3DMark tests boggers up the average value. Ambient temp was always between 19.0 and 20.5 °C. Ambient/water delta was between 2 and 3 °C at idle and between 5 and 6 °C under load. Temperatures on air are in BLACK and temperatures on water are in WHITE.
...................Idle (°C)...Prime95 (°C)...3DMark06 (°C)...RTHDRIBL (°C)
CPU_________27 / 19.......38 / 26.............41 / 28............36 / 24..........Air / Water
NF4 chipset....42 / 27.......42 / 29.............46 / 29............44 / 29
GPU core_......43 / 31.......44 / 31.............73 / 35............58 / 32
I've always had Cool'n'Quiet enabled so maybe that's why the CPU idle/load deltas still seem a bit high? Either that or the Storm is mounted badly :(.
Yeah I'm really pleased with the MCW60, it's bolted onto the GPU pretty tight though. My old case was really cramped with poor air flow, I'm pretty sure that's why the GPU ran so hot.
Some post-build updates...
Well I thought my computer was still a bit too noisy, the worst offenders seemed to be the pump, the Storm block and the hard drives.
I had a spare block of acoustic foam left over so I cut some to fit on the top part of my DDC pump, and I also put a PT gel-stuff pad underneath the pump. Can't feel any vibrations from the pump now. ;) I was slightly worried about the pump overheating by doing this but I measured the temperature of the bottom of the pump to be ~40°C, which seems safe enough. The top section of the pump is only in contact with the coolant so I guess you can wrap that up as much as you like. The bottom section houses the motor so I've left the sides exposed to some airflow, which seems to keep it cool enough.
I was surprised how loud the Storm CPU block is. Since it's a jet impingement block it sounds a bit like a shower head. I hollowed out another piece of acoustic foam to fit snugly over the Storm, which cuts out a fair bit of the (high frequency) noise. It's still by far the loudest part of my computer though. :(
My two hard drives were causing the case to vibrate quite a bit so I elastically suspended them with some Stretch Magic cord. This really reduced the idle noise and the seek noise, especially from the Raptor. The drives run slightly hotter without the sides in contact with the case, but having some air flow over them seems to keep them cool enough.
I think I've reached the end of this project now. The only thing that still bothers me are the PSUs. I'll get fanless/modular ones next time...
