Project: DOOM - ZenModz
Looking good dude, some top talent with bits so far. What are you planning on doing with the skull and hand?
Cheers Kilbane. Thats still a secret :P
Hello again.
Not giving to much away on the case ATM. But it is well under way.
if anyone wants to know how the can it still be opened I'm making it so all the panels can still be removed.
To start the ball rolling here is the Mobo process.
The Mother Board going into the Doom build is the ASUS Sabertooth X99 2011-3
The link can be found here : https://www.asus.com/au/Motherboards/SABERTOOTH_X99/
I think a very cool looking Mobo to start with for the Doom case. and should work well with the theme with it's armor plate cover.
What I like most about this Mobo is all the extra bits that come with it like the PCI-e covers and a plug for every thing plus a fan that can be add to the Mobo for some better cooling that I'm going to be using.
Plus you get 4 ram bank fillers to hide the empty ram slots. as well as 3 thermal sensors that plug into the Mobo.
So to start off I have removed the Armor to get it ready for it to be painted in silver.
Ok here come all the PC goodness so I wont do much more talking as I know most of you will just look at the pretty photo's
All Silver. :)
Adding a small amount of yellow. more yellow will be added to the inside of the case later.
Here I also repainted the text onto the hole mobo. to make it all stand out.
For the next photo's I have done a small amount of weathering on the Mobo.
Thanks to Cooler Master and AVEXIR I get to use some sweet looking BLITZ Series AVEXIR Ram. You just have to love how good there ram looks.:D
But I'm still going to mod it just a bit. to work in with the look of the Mobo.
Black.
Now silver.
And now even sexier then before.
Here is the Mobo completed :P
That it for now, As always thanks for stopping by.
Love it, love it, love it! Not giving to much away with the case ;) and the mobo looks well detailed. Kudos
Hello again.
First off for this week Cooler Master sent me some A cool t-shirt and a drink container for being part the the Cooler Master World Series. Thank you CM I will wear it with pride, :thumbup:
Sadly Ive been told I look bad in photos. What do you think ? I was Home Alone at the time. and was a bit scared when the flash went off :D
So the build is still moving along, I started off making a airlock door. and some rails for the inside and some other parts, then moved on to the case again.
The Rails relay suck to make. just my 2 sense worth. And yes I need to make more! :upset:
All of this build is hand made, cut out mostly with a sharp blade and other hand tools.
Still adding to the look of the case as I go. Below is where I'm up to so far.
Some parts are being shaped with sign foam to make it a bit quicker.
That's about it for now. I'm waiting for the water cooling gear from Bitspower to arrive then I can start getting the inside up and going as well. :D
But for now I'm trying to get the outside all done, Not all that much more to go on the outside. just lots of small bits.
Again thanks for stopping by.
