Hi All
Been having issues with my pc since I tried to reboot it last night. I'm hoping you guys would be able to help me figure out whats wrong with my rig please.
I was playing some pubg and watching some twitch. Then l restarted the pc and it didnt come back on. I tried a few times with no luck, so I disconnected the power for a bit and tried to reboot again. Now it turned on but there's no out put to my 2 monitors. Everything seems to be powered on the 1070, ram, kraken all light up and the pc seems on, but I noticed on the 1070 the fans try to spin, they do a small sort of shunt movement on one fan then it does it on the other, no full spin.
So I tried the 1070 in my daughter's pc and it seems to work on there, the fan spin up and it boots into windows on her monitor.
Then I thought I'd try my daughters older r9 280x in my pc to see if I could get anywhere, there's no output to the monitor's or any of the 3 fans spinning on it at all.
I was thinking maybe I should try using a different power supply or look at replacing the motherboard.
My pc specs are
i7 5820K | Gigabyte GA-X99 Ultra Gaming RGB | Corsair DDR4 Vengeance LED, PC4-24000 (3000) | Nzxt Kraken x62 | Evga gtx 1070 sc 8gb | Corsair AX850 | CM Storm Stryker
Thanks for looking.
Flux
My pc specs are
Thanks for looking.
Flux
