Rastalovich
Whilst at work.. ..came home, gaming pc - G15 had no lights >.<
Reset it, screeeeeching during windows boot progress thingy, halts then blue screen.
Dos works fine, bios ok and temps fine. (well still a quick flash from 30 to 12 degrees lol)
Think the harddrive died !!
hehe where are those cheap 80g drives . . . . .. .
I`m on the case ^.~
EDIT: eh, ok well I was going to install 64bit anyway, so that`s that - but the harddrive is ok.
I have a screeching sound coming from the cpu/mobo section when the cpu does any work !?!
I`ve touched each fan with a finger to stop them (thinking something`s brushing or something - but no)
I push down slightly on the Ninja and the screeching stops.
Only happens when the cpu does work, might strip the thing down 2morrow and re-apply it.
It`s really weird, like listening to an old C64 tape loading.
I`m on the case ^.~
