Havent started to use it yet. Will do in the next days to come. The ram will most likely be set to stock because a workmate of mine is buying it. Also swoping the cpu with a 3570 so the new owner will have some more horsepower.That looks so freakin clean, great job! Did you manage to clock your RAM any higher than stock? I have the same set and they clock very well (at least up to 1866, my board doesn't support faster x-P).
Thanks fellow NorwegianJust read the entire buildlog and I just gotta hand it to you dude - this is realy something else! Minute detaling, thoughtful execution, playful colours that speaks both to the original case-design as well as your many mods.... not to mention all those amazing photos you accompanied this log with...
Pretty close to blown away by your amazing skillsets and imagination
You Sir - are a "modder friggin" ACE in my book! :notworthy:
Stå på Azurite - Vi vil se mye mer fra den kanten![]()
