Pastime Project
Got the package i needed for custommaking the pcie/sata power cables. Ive finnished the two pcie cables, replaced the wires, better crimped and also made them correct lenght for the Prodigy. I really dont want a lot of extra lenght of cables in this tiny case :)
The stock pcie was belted togetter and they were very stiff, thick and also with crappy insulation. Sata power cables up next :)
First sata power done:
Today i have modded the two Silverstone 180 fans further. Ive changed all the wires into white ones and custom lenght so it will be perfect lenght to the power source and the fan controllers. I have sleeved both of the m also but i havent taken any pics of them yet. Il run a test on both later tonight to see that they dont shorting out or something. I was a bit worried that one or two soldier points where toutching eachother. I heated up a knife and i draw it between the points so they dont have any contact. I hope that did the trick if there ever was contact. Be back with some more later tonight.
The fans are tested and they are both running perfectly . Im very happy about that since ive never soldered fans before, and i am also now 100% satisfied with how they look. I made a scratch 4-pin molex psu cable tonight aswell
Some UV shots of the cable i made.
Hope you like it and thanks for stoping by commenting and watching
