Just a few hints about P45 Chipset Overclocking:
P45 chipset is made by 65nm process, P35 and 965 is by 90nm process. If you put high voltage on P45, the oc result will be worse not better.
for P45 OC, NB voltage can be left at default value if users are overclocking below 400MHz. for FSB 400-500Mhz maybe 1.3v is enough. 1.4v for 500mhz and above should be enough. anything higher than 1.4v could hamper the oc rather than help.
Also the CPU VTT value should be higher than NB voltage but not higher than 1v than NB voltage.
