Reloaded2
Hey,
Recently I upgraded my ram from 16GB of Corsair Vengeance 1600MHz to 16GB of Muskin Blackline 2133MHz RAM.
Now my motherboard (MSI p67a-gd53 b3) on the latest BIOS wont run the XMP profile which is at 2133MHz. I mean the PC wont load at all (just restarts itself) - it wont even boot into the BIOS. I checked online at it says the motherboard supports up to 2133MHz. I have to clear CMOS to get back into the BIOS because when I activate XMP the PC will just restart itself. By the way the ram is rated at 1.5V which I think plays apart in why the PC wont even boot into the BIOS when XMP is activated because I think its not enough voltage at the older LGA1155 chipset.
However when I manually set the DRAM frequency to 2133MHz and manally set the RAM Voltage to 1.655V the PC loads into the BIOS and recognises the 2133MHz OC but when I try to boot into the OS it come up with a black screen saying hardware changed and wont boot into the PC.
Now when I activate XMP, manually set the DRAM voltage to 1.655V; it boots into the BIOS fine and recognises the OC perfectly. And it also recognises Windows and boots into windows but as soon as the OS is loaded I am greeted with a blue screen which is better progress than the black screen but now I am blue screening
When I run the at 1833MHz and 1.65V (even though the RAM is rated at 1.5V) the BIOS and PC run perfectly and it runs fine under a stress test of Prime95 using my 4.5GHz OC on the CPU, but as I said this is 2133MHz RAM and I want to run it at those speeds becasue I spent £85 on the RAM.
I have turnt off my overclock on the i5 2500k so its on stock speeds and stock CPU voltages to eliminate the CPU OC being a factor and I have the latest BIOS (4.3). I am also using an RX 480 and an SSD to boot windows.
This should be enough information for you guys to go on and I hope we can get this issue fixed soon
